Help with CVR camera compatability
Hi,
I was told by arlo I need a CVR plan because I've been using too much cloud space.
But the camera we had isn't compatible. I've now just bought an ARLO pro 5 spotlight camera. Does anyone know if this is comptable with CVR?
The guy at arlo wasn't helpful at all.
It is, but you'd need to connect it to a compatible hub, and also supply AC power to the camera.
If you get a VMB4540 or VMB5000 for the Pro 5s, then you could drop the subscription (avoiding the need for CVR and AC power). Then use direct access to local storage. The experience isn't as good, but Arlo would stop bothering you.
Another option would be to make adjustments to reduce the amount of recording. Those include repositioning the camera, adding activity zones, and reducing the motion sensitivity. How far was the camera over the storage quota?
BTW, what was the original camera?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
