how to change address in profile?
How can I change my address in the Arlo Profile from Canada to Hong Kong????
This is all optional information.
Can you PM me with the address you would like to use?
Are you having an issue with inputing the address, do you receive any error messaging?
Can you provide a screenshot if so?
I cannot change the country in the address screen.
Anyway, I guess it doesn't matter as long as you get your monthly fees.
The country is set when you first set up the system. You'd have to uninstall the system (and maybe create a new account in an appropriate country, perhaps using VPN) to "change" the country.
Arlo Pro 4
labels
Samsung SmartThings
