Hi Everyone!
I need your suggestions and help with regard to the best and most secure brand gutter mount for my newly purchased Arlo Pro 4 camera and the Arlo Solar Panel. I am in Australia but should matter anyway. Thanking you in advance for your help!
Best Regards
Kim
Best Regards
Kim
I like these...tho there are many , not sure what's available in your locale .
https://www.amazon.com/Arlo-Gutter-Mount-Weatherproof-Compatible/dp/B07Q58Q6Q9
To set up your Arlo Solar Panel
You can mount the solar panel on your wall, fence, roof, gutter, or eaves. Make sure that you mount your solar panel facing true south (in the northern hemisphere) or true north (in the southern hemisphere). 2. Secure the mount with the screws provided in the package.
Arlo Pro 4
labels
Samsung SmartThings
