  • 8 Replies
  • 3449 Views
JRogo
Help!!!! Videos stopped recording last week. I've talked to Support - I've tried reset multiple times - wifi is fine - checked modes - NOTHING. This seems to be a common problem. Any other solutions? Seems to have coincided with signing up for Arlo Secure after the three-month trial. Only one of three cameras.
JRogo
“Support” was not helpful but randomly the camera starting recording again. 🤷‍♀️
8 REPLIES 8
Are all cameras listed as active in Settings, Subscription, Manage Cameras?
JRogo
Yes
Can you live view and manually record with this camera?
JRogo
Yes and yes
Then the next step is to try the motion detection test on the camera that isn't recording.
https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
JRogo
I checked the Motion Detection and the amber light turns on when there is motion.
Still nothing. Can Arlo replace this camera??
Don't know, you'd need to contact support.
Though it's not clear to me that this is a camera problem (since the motion detection test works).
JRogo
  • 8 Replies
  • 3450 Views
