Arlo Pro 4 - Timing out
  • 5 Replies
  • 2513 Views
fordgt
So,
I have a MikroTik Router. On the router, I have a 10.0.0.0/24 network and a 172.0.0.0/26 network. The cameras show up on the 10 net, but I can not connect to them as they time out. However, when I put them on the 172 net they work normally.
Here is the kicker, I have no rules set up on the ether network everything is the default. Also, all my other smart devices (Google Home, Smart Lights, etc..) work fine on the 10 net. This is very puzzling any help would be greatly appreciated.
Thanks in advance,
Chris
fordgt
Thank God! I have the solution. I spoke with MikroTik support and they told me to adjust the interfaces settings. Apparently, the 10 net was not a LAN interface on the router. Now while that doesn't explain how the other devices were working on the LAN at least the cameras are working and hopefully, this helps if anyone else has this issue in the future.
The settings I changed were under Interfaces> Add New > List = LAN, Interface = VLAN XXX > OK
5 REPLIES 5
I am thinking that your phones and PCs are also on 172.x.x.x - is that correct?
fordgt
It is a mix, some PCs are on the 172 and some are on the 10. I get the same results if I try and view the cameras from LTE on my phone. Either way, all other devices on the 10 net are functioning as normal as far as I can tell, minus the cameras.
Thank you for your interest.
The cameras/app might be confused due to the two different subnets - not something I've tried.  Though I'd think they'd still work on LTE ok.
Obviously you could just keep the cameras on 10.0.0.x.  Not the best answer for you though.
fordgt
Great!
Thx for sharing the solution.
  • 5 Replies
  • 2514 Views
