The upgrade notification popped up, made it sound like any other wonderful thing to do, but I'm SO disappointed and wish I would have never tapped that button and given permission. 😔
And it's just the everyday simple things, that yes, I was used to, but are just now, irritating.
For instance, swiping from video to video. Why should this be so difficult? In most cases, I skip over some, and have to go back to the original "list", and start over. And that's going through and finding the correct "time" where you left off. So if you're looking for something specific, it's time consuming and well...hard to do.
Trying to go to another day or another week, is worse. I realize you can go to the "week" calendar, but finding what you may be looking for in the past is not like the "past".
Another irritating thing I find is scrolling through my videos. Either my finger is "off", or it's this new upgrade. It's not scrolling friendly, it takes a couple tries, or skips to the next videos, and there isn't a way of seeing this, unless you get out and start over.
Which leads me to the next issue. When watching the video, if I want to zoom in while watching, this is nearly next to impossible. It will take some doing. It will also take me to the next screen instead of zooming in to what I want to zoom in on.
Also...when watching videos, and this is all since upgrade, (I just can't believe how bad all this got), but the videos are "live looking". They go in seconds(?). It's hard to explain, but people, animals, etc. stop, then start, stop then start. 🤦🏼♀️
Cameras aren't picking up "things" as well. Have a doorbell camera, but also have a camera above this area. What the doorbell picks up, the "above" camera will not "catch" at all, which it clearly should. I see the light go off, (the light from camera above on the doorbell camera), but the above camera doesn't catch "it".
Everything has changed since the upgrade, and this is from day one. I pay yearly, (also a price increase), and I am very disappointed.
I SO wish I didn't get the upgrade, or I SO wish Arlo could reverse it.
Does anyone have any of these issues? I can't believe it could only be just me?
Please Arlo support, I hope you're reading this.
This link provides information regarding the new app as well as ways to set up modes within the new app. If you have any questions or need help with anything after reading through this link, please let me know and I would be more than happy to help.
https://www.arlo.com/en-us/new-arlo-secure-app
No, this didn't really answer or help my issues. With the upgrade, I'm still having trouble with the videos not coming through as consistent. They are still stopping and starting through the viewing of each individual video, and some even miss parts and go from (I.E.), one part of the yard, immediately to the next. (Makes checking on my dogs difficult). Also, swiping from one video to next is frustrating. Takes either multiple swipes or tries, or goes to the next couple of videos. Also, "zooming in". Next to impossible. Used to be so easy. Now is so difficult and sometimes, most times, takes me to the next video when trying to zoom in too far over to one side. Very frustrated still.
Am I doing anything wrong? Is there ANYTHING I can do to fix this or on your end? I never had an issue with Arlo before this upgrade, I was happy with it. But all this started on day one of upgrade.
Can you please send me a video showing the inconsistency with the video? You can send that via dm. You send a dm by clicking on the envelope icon on the top right of the forum page.If you don't see it, then go into your profile settings and select preferences, then "Private Messenger." Then select "Turn on private messages" if it is turned off.
Hello, I know this sounds strange, but, when I download the videos to my phone gallery, and playback, they are fine. They play fine with having no skips in the video. I tried on all three cameras. Is this a clue of what might be going on? For example of what's going on, yesterday in the backyard, my pup was on one side, and it skipped to about half the yard over. Any ideas? Might also have something to do with zooming in, scrolling?
Thanks, Tracy
Are you using an Android devicde?
Yes, but I always have. Nothing is different except day one from upgrade.
We are investigating the behavior you are seeing. I will provide an update as soon as possible.
Are you still seeing this same behavior?
I’m having the same problems or worse since the wonderful upgrade. Here is my issue, I want to drive my car but not be the mechanic. Arlo needs to realize their system is a tool. I want my tool to work. My Arlo system (tool) was working okay until I did the so called wonderful upgrade. Just today …… was totally busy and not paying attention to Arlo since the upgrade. Now I learn there are problems. Now I read other people are having problems as well. This is an ARLO issue. ARLO, FIX YOUR PROBLEM………
Can you provide more information on what you are seeing and what you are needing help with?
Arlo Pro 4
labels
Samsung SmartThings
