Unable to do live view and motion recordings missing
Tonered12
Arlo website says they fixed this issue 20 minutes ago but I’m still unable to see any recordings or get motion notifications for the past hour. I am unable to select live view either does anyone else have this problem still?
ShayneS
Thank you for providing your feedback. The symptoms with missing recordings and delayed live streaming  should now be resolved. Please let me know if you experience this again.
You can find more info here: https://status.arlo.com
Best answers
  • ShayneS
    This should now be resolved. Please test again and let me know.
    Thanks!
  • ShayneS
    Thank you all for providing your feedback. The development team is investigating these reports and I will provide more information as soon as possible.
42 REPLIES 42
TacoTuesday
Live view and video recordings are not working for me either.
SciTeacher
It’s 1:08 Eastern time and I am having this issue. For me, the issue started around 11am. I reset and hard reset my base station as well as taking batteries out of cameras and putting them back in. I cannot view cameras live and they are not recording. What is going on?
TacoTuesday
It’s an issue on arlo’s end, not the customer side. They need to fix it on their systems. I’m in the west coast so it sounds like it’s a problem nation wide. Can someone from support please chime in on this?
SciTeacher
Thank you for the reply. I hope it gets resolved soon.
SciTeacher
Do we know if Arlo is aware of the issue?
They are.  See https://status.arlo.com/
Though the website claims livestreaming is working, it is not working for me.  The system says "Connecting" for a while, and then gives up.
Qrylander
Not sure what happened, my cameras all have a strong signal to the router and have 80% or more charge but all of a sudden do not show the live feed and stopped recording/detecting motion. I have no clue what happened
TacoTuesday
Their system status says recordings are down only, but that’s partially true. Live stream is also down even though they say it’s up.
SciTeacher
That is exactly what it does when I try to view live stream. It will also indicate that it senses motion but will not record. Thank you for your reply.
ShayneS
Wilburdoo
Status site is showing an outage for video recording.  Live Streaming is also down.
Just1Guy
Having the same issue.  It’s now 1:31 cst and cameras haven’t recorded for 3 or more hours.  Not home right now and actually had an event.  Received 12 or so camera alarms and not one recording.
Fortunately it was my daughter and she called.  Had it been a true break-in I would have had no recorded evidence. This is awful.
SciTeacher
Update 3pm.
Looks like my issue is mostly resolved. Live is now working. Recordings and recording notifications are showing up in library but are very slow to do so.
ShayneS
SciTeacher
As of 5:30pm Eastern, cameras are set to 100% to detect motion. They are slow to detect motion and don’t detect motion of my pets. Recordings are still very slow to show up in library and give notification minutes later.
123property
Sent chat to support and it was fixed in a couple of hours. Thank you!
Tonered12
Are your recordings lagging as well? Mine is taking a minute or so after it picks up motion
SciTeacher
Yes, they were. As the evening has gone on, it seems the issues are getting resolved. My service is pretty much back to normal.
Tonered12
Hi Shane, I’m seeing other posts in Reddit as well as my own experience that after the fix was implemented the app is running much slower. There always was about a minute delay from the motion event to notification and now it’s over that and even opening the app itself is slower
ShayneS
@Tonered12
Is this affecting any specific devices? I tested this and the Arlo app is loading and cameras are live streaming within a normal timeframe.
Tonered12
Hi Shane, it’s all devices I have Arlo 4s and essential cameras as well as a doorbell.. I am also experiencing issues this morning not able to do live view and missing recordings
Tonered12
  • Other users are reporting the same issue to me in another forum as of this morning , missing recordings and unable to do live view option @ShayneS
SciTeacher
Yes, I was just coming on here to see if others are having the same issue again this morning. I cannot view live feed and I am not getting any recordings again. @ShayneS
bhb1717
Live view and video recordings are not working for me. Started not working on 7/25/2024
