@Morrison58 wrote:
When home internet upload speeds are slow (under 8Mbps) what can I do to reduce bandwidth usage? The cameras are advertised as having 2K quality. How do I reduce that to say Full HD?
Turning on "auto zoom & tracking" in video settings will result in getting 1080p.
Though you might not need to do that - are you seeing any signs of not having enough upload speed (for instance, corrupted recordings)?
Started using this set 3 days ago by installing one camera at a time. No problems and all were online and were triggering on movement and sending notifications and making recordings.
But yesterday one of the 4 cameras went offline so I had to remove and add it then another went offline so I did the same for that one. However now even though all cameras can allow live viewing only 2 trigger and make recordings.
A live chat with technical support suggests that my home internet upload speeds are too slow. Speedtest.net says it is around 7Mbps. Support says I need 4Mbps per camera.
This says 2 mbps for the the Pro 3/Pro 4: https://kb.arlo.com/000062043/What-are-the-minimum-requirements-for-installing-and-using-my-Arlo-sys...
OK thanks perhaps Support was mistaken.
I've changed one of the cameras as you suggested then found one of the others has gone offline.
It could be a bandwidth issue (as support thinks). Or it could be local connectivity.
- What signal strength are you seeing in the app for the cameras?
- Also, what upload bandwidth is speedtest.net reporting?
I've tried all 4 and none can be found by the app. I've rebooted the modem/router, removed the battery from 3 of the cameras but still can't get a camera to connect.
@Morrison58 wrote:
When they were working it was Strong. Speedtest.net is reporting 7Mbps consistently.
If you select the library, are you seeing any recent recordings?
@Morrison58 wrote:
Yes I am.
Ok, so the cameras are recording to the cloud at least sometimes.
Are you seeing the offline message immediately in the app, or only after you try to livestream the camera(s)?
I can't remember if I have mentioned this to you as I am emailing with Arlo support but I have removed all cameras, removed batteries from 3 of them and tried adding the remaining camera. No luck. The whole system is dead.
Many thanks for your advice and patience.
Arlo Pro 4
labels
Samsung SmartThings
