Issues with Arlo Pro 4 Cameras
I purshased the Arlo Pro 4 XL camera a month ago.
I noticed that the camera are either set off with nothing there constantly or they won’t activate with motions 50% of the times.
I tried resetting the cameras and also tried resetting the hub. I also tried various motions sensitivity levels and still same issues.
The second issues when ever its humid or rainy you can’t see anything out of the camera they all fog up badly.
I have own Blinks, and Lorex and they work 10 folds better and never ever foged up!
I purshased this thinking of getting a better system but so far its pure garbage! Is there way to fix these issues or best to go back to my blink and lorex system.
thanks
@asinameli wrote:I noticed that the camera are either set off with nothing there constantly or they won’t activate with motions 50% of the times.
Are you literally seeing it trigger with no motion at all? Or is there some motion (wind for example)?
There are some treatments that can help (RainX or equivalent).
Some third parties also offer rain covers that might help (never used one, so I don't have a specific recommendation).
Arlo Pro 4
labels
Samsung SmartThings
