I have Arlo Pro 4. One of the units display a reddish tint. Removing battery a shaking the unit did not fix the problem. Rejoining the network did not help either. What is next?
Assuming you have a subscription, use Settings, Support (Center) to choose your camera model and get choices to contact official support for a possible RMA.
If the camera was just purchased, it will be faster and cheaper to exchange it with the seller.
Arlo Pro 4
labels
Samsung SmartThings
