We successfully granted access to an additional account so that my husband and I can both receive notifications. This was done a few days ago. My account (the shared account)was successfully receiving notifications until this morning.
My phone is not in Do Not Disturb mode. Double checked my notification settings. I tried uninstalling and re-installing the app. Nothing.
I determined it is not my phone because I logged into my account on my husband's iphone and do not receive notifications, while when logged in under our core account, the phone receives them. The same occurred when I tried this with our ipad.
It must be something having to do the shared accounts.
Please help.
Oh and to add, I logged into my phone with the core account and the notifications are working. So, it is definitely the Arlo app and not my phone.
The dev team is currently investigating reports of this issue. I will provide an update as soon as I have more information.
Are you on iPhones? If so, check for any updates. Both my phone and hubby’s needed a minor iOS 15 update.
Then remove all the people you’ve given access to. Log out and back in to make sure your account is showing that you’re not sharing with anyone. Then try adding again. This step brought back notifications on the main account for me. Hopefully it’ll fix for you here.
If not, remove base station and cameras from account. Then add back on. I got a few cameras to work with this step.
Anyhow, I did these things many times but basically deleting everything and starting over did the trick. Hope this helps!
Hello. I have an ARLO base station with cameras connected. everything has worked fine so far, but suddenly I don't get instant notifications about detected motion in the ARLO app on my phone. I receive email notifications, but I don't receive gadget notifications on my phone. i don't understand what happened and i don't know how to fix it. I tried everything: I reloaded the base station, removed it and reconnected it in the app, I added all the cameras again, everything is fine in the phone settings, but I don't get instant notifications about the detected motion. I just stopped receiving notifications one day. I am asking for your help. What happened here and how to fix it?
Have you Uninstalled and Reinstalled the app ?
yes i did it but it didn't help
There have been recent reports of this. If you have shared access with anyone, have them actually log out of the app to see if that helps. Removing their access from Settings, Grant Access also works but that's pretty brute force.
the interesting thing is that the person i share is getting instant messages on his phone, but i don't get it. maybe it's a problem with my phone's settings, but i reviewed all the settings and everything looks fine.
Have you rebooted the phone?
Yes, of course. The RLO application is granted full permissions and is allowed to display messages. I send screenshots of my phone
WHat phone and OS?
phone Caterpillar CAT S52, software for Android 10
Hmmm... Can't help you there - it may be a phone thing or older OS issue. If you temporarily subscribe you can try support via Settings, Support to report this as possibly the same issue as the others. When done dealing with support, unsubscribe.
thanks for the effort
Several others have reported this. I think you'll find that if you stop sharing the cameras, you will start getting notifications again.
I didn't update arlo app, change any settings of it, didn't update my phone, install any new apps from android's play store or update any app that should change what screen shows. The same problem is also with my wife's phone and I didn't do or she didn't do anything that should change notification behaviour.
I read that my both hubs 5000 and 4500 got a firmware update at the same time the problem started so I'm quite certain that those updates had a configuration mistake or the cloud system is now buggy.
This happened to me as well. I have been working with Arlo support and have jumped through a lot of hoops working with them to resolve this. Nothing yet. I will post when resolved.
Arlo Pro 4
labels
Samsung SmartThings
