Pro4 set up problem.
New system installation. Camera and internet are on. When the QR code is scanned and the system is searching for the camera it fails to find it and gives an error of camera is off or internet is not working.
If you are using the app, then I suggest also trying a PC (browse to my.arlo.com).
Also, check that the wifi network security is set to WPA2 (AES). If you have special characters in the network name or password, then I suggest removing them. Some characters get in the way, but unfortunately Arlo has never said which ones.
Arlo is just maddening. I have spent 7 hours trying to set up two new Pro 4's. I have one connected so they cannot say its the WiFi. Fully charge, blinks blue. Sees QR code and Chimes. Tried 15 second rest. tried antoehr new battery. IT CANNOT FIND THE CAMERA. This is not ok. And there is no live service just chat that spends hours of time over many days and it still wont work.
Having the same problem with cameras not connecting. Confirmed wifi is on 2.4 setting, one camera finally liked up. Tried factory reset. Chimes and then it says cannot find the camera. So beyond frustrating and no phone number for customer service is also frustrating. May return product and buy another system.
QUIGG, GTMartin
Try attaching the included charging cable and then attempting to sync again. Do you still experience the same behavior?
Arlo Pro 4
labels
Samsung SmartThings
