Tried resetting after failed connection, reads QR code just fine and chime- then flashes amber quickly and appears to shut down. Battery is fully charged.
Solved. Had to contact internet provider and establish another password protected WiFi signal from the router.
npecktexas,
This could be an indication that you're entering the SSID/Password information incorrectly. Be sure you're entering the information exactly as it appears for your home network.
Arlo Pro 4
labels
Samsung SmartThings
