When will Arlo subscription plans be available in Brazil ? I just bought a new Pro 4 and it's useless as is.
How come an online service is not available worldwide ?
As noted in the FAQ here, only certain countries can get subs. I suspect it's due to legal issues.
You can connect the camera to a hub (I suggest the VMB4540) so you can record locally. It's not the same as cloud recordings but it's better than a sharp stick in the eye. Your other Arlo choice is to return the Pro 4 and buy a Pro 2 system so you get free cloud recordings.
Arlo Pro 4
labels
Samsung SmartThings
