Purchased a VMC4050P (yes, that is the correct Model) and a Smart trial included. Smart trial ends, but I cannot subscribe to Secure. I get endless loops of logging in over and over. One of the links tells me I have no cameras in my account when I can see my camera in my account. Very frustrated!!!
Frustrated_too,
Try removing the camera from your account and then re-onboard as if it were new.
You may need to manually factory reset if the camera has issues being discovered, see here for instructions: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
After the camera is onboarded again, navigate to Settings > Subscription and attempt to add a subscription to your account. Do you still experience the same behavior?
Have you tried using a computer web browser to do this?
Yes. I choose to Join the Plan and it immediately asks me to login again. Working from my settings screen, the same thing happens. It won't let me buy the Secure subscription.
Frustrated_too,
That worked. Thank you for the assistance.
Arlo Pro 4
labels
Samsung SmartThings
