Arlo Pro 4 blue led keeps blinking
  • 9 Replies
  • 4300 Views
AFreeze
I have an Arlo Pro 4 camera. When I have it plugged in the blue light flashes all the time. Is there anyway to stop this excessive blinking? I have deleted and reinstalled this camera multiple times.
9 REPLIES 9
There is a Camera LED setting in the app that lets you turn the Battery Fully Charged Indicator off.  Have you done that?
AFreeze
Yes I have done that. Still have a camera that consistently blinks the blue light like it is trying to get on the WiFi when I have it plugged in to the wall outlet.
Is the camera going offline (or giving other indications that WiFi is dropping)?
Maybe try rebooting the camera (remove power, including the battery - then restore power), and see if that resolves it.
FWIW, my Pro 4 is on battery, but I have a powered Pro 3.  I'm not seeing the blinking blue LED with the setting set to off.
AFreeze
I have not seen any issues with it dropping WIFI.  I have taken the battery out, rebooted the camera, removed it from my account and re-added it.  None of these things have helped.  I have actually plugged in another camera to this cord and it did the same thing.  I think the issue is the Arlo Cord and not the camera.  Wondering if there is any warranty on the cable not working ?  If I unplug the camera from the cord and just run off of battery I don't have a problem.
AFreeze,
Do you have any other cameras you could test the power cable on to see if the behavior is the same?
AFreeze
Yes I have tried the power cord on two additional cameras and the effects are the same. Without the cord the cameras work fine. Plugged into the cord the blue light starts flashing excessively.
Angela
What type of cable are you using? Is this the standard indoor charging cable or the outdoor charging cable? Is it Arlo branded or third-party?
AFreeze
The cord is an Arlo power cord. It is an indoor power cord. I believe it is 10 feet long. It was ordered through Arlo.
Angela
AFreeze,
I encourage you to reach out to Arlo support to further investigate this issue. You can find support options within Arlo mobile app: https://kb.arlo.com/000062610/Arlo-Support-Options
  • 9 Replies
  • 4301 Views
