I had an Arlo doorbell. I was told by Arlo support that if I had a hub, I would not need a subscription. I purchased three pro 4 cameras and a hub. I get notifications but no video to the library. I do not want a cloud subscription. Is it possible to access videos without a subscription?
Use the app (web client won't work) and go to the library. Near the top is a pulldown menu - choose your hub instead of Cloud.
Did you
- connect the Pro 4 cameras and doorbell to the hub (instead of your home wifi)?
- add USB storage to the hub (at least 16 GB)?
- enable "direct access to local storage" in the app?
More info on direct access can be found here: https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Cameras are connected to hub, with USB and direct access to local settings is on.
Arlo Pro 4
labels
Samsung SmartThings
