FrustratingI have three pro 4 cameras that I purchased for security on my house. Thes are high end cameras that won't stay connected to the wifi even when they are 10 feet away....well, one is near 30 feet and never disconnects. I have reset these things dozens of times. I will get them to connect in the house and once I put then on the mounts outside they disconnect. I'm running the eero wifi mesh system and I have 5 access points so there should be no reason they shouldn't stay connected!!! Yes, I disable the 5g so the cameras link to 2.4g. This is such crap!
Since they work inside the house it would appear to be a signal strength and/or quality issue. House construction can cause this (think stucco, brick or stone) as well things on/in the walls the signal has to pass through. There's also the possibility of 2.4GHz wireless interference from some device.
I'm so glad to know I'm not the only one experiencing poor performance with these things. The two camera system I recently bought is causing me frustration with the way they intermittently go offline and Disarm mode may or may not work. Overall the integration between the cameras and the iPhone app is just sluggish and often non-responsive.
I'm sure they'd be inclined to blame my WiFi but we pay extra for higher speed through Mediacom, my wife had them setup a 2.4g specific connection and anything else connected to our home network works just fine.
Greg_Midi,
If your cameras are going offline intermittently, this is likely an indication of a connectivity issue. What does the signal strength icon show for the cameras when they are online?
Unless there's another way to view, the typical wifi bars appear strong, it's unlikely to be a signal strength problem. I stopped turning them off/on and try just to use the disarm. They do however continue to go offline randomly for no apparent reason.
Greg_Midi,
If the WiFi icon shows full and you're still experiencing issues with the device dropping offline, I recommend that you contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
I have an interesting update....
We recently moved from the upper midwest to the southwest (IA to NV) and these cameras seem to work a whole lot better with the internet connection we have now. This is hard to explain or understand, in both of these areas we have/had the highest bandwidth connection available. In the old place we had little to no trouble with any other wifi devices other than these cameras but now they seem to work just as well as any other of our wifi devices.
The problem was obviously network related but the why is baffling.
I guess it's a good thing that your cameras are working now despite that the cause of the connection issue is still unkown. I had similar issue and one change that made some improvement is that assigning static IP to my cameras. The cameras can still go offline but very rarely now. I suspected IP conflict could be one of the reasons why cameras can go offline occasionally but this is yet to be confirmed by Arlo official.
I have been having problem with the Camera stay connected... I have called Supporting Several times they keep hanging up on me and I am yet to get the issue resolved... I paid too much for the cameras to be going thru this mess
I am lost and wish I could take them back I have only had them 3 months I also have a pro two I just both and it will not connect... I am so frustrated at myself for spending my hard earn money on this system
So looking a little deeper it turns out that our former connection, which was the fastest available, was only up to 300mbps while this new connection is as high as 1000mbps. Perhaps the bandwidth/speed is the differentiator here.
I'm having the same problem! Arlo tech told me to use the Pro Hub to fix it.
@Hugh_ I'm wondering if there has been a firmware update that is causing problems.
The lasted FW update listed in the FAQ at the top of this forum is September.
Thanks. Then it is not a firmware problem.
That is, it is not a new firmware problem.
Hugh_, Jmarsden
Consider removing the camera from your account, factory reset using the steps in the article linked below, plug the camera in using an Arlo charging cable and then attempt onboarding again. Do you still experience the same behavior?
How do I factory reset and re-sync my Arlo camera?
RiahWillow,
Arlo Pro 4
labels
Samsung SmartThings
