- 2
My cameras were working just fine. I was able to quickly access the phone app and set individual cameras on a schedule that I liked i.e Living Room camera on at 12am - 6am. I didn't want to capture family walking around the house during the day it'll midnight, so I could easily set it the way I wanted...NO MORE! These crazy routines they came up with especially "Standby", "Add an Automation" and "Add an Action" are so confusing it's super frustrating trying to figure this new software out. You need to take a class to understand the way this works.
It's SLOW to load on my iphone unlike the previous version and the pictures don't load all the time on the "Dashboard". I'm really pissed they forced us to use this crappy app. I WANT MY SCHEDULE'S BACK. Now I have to completely turn off certain camera's when family is over to prevent the batteries from draining, do to the horrible changes in this app. PAID customers should have the option to upgrade or NOT or down grade to the previous version. I have read the help files 100 times and still don't get it. Standby is super confusing. THIS IS NOT BETTER OR USER FRIENDLY.
Best answers
Thank you for your continued feedback. The development team is monitoring these concerns and improvements are coming.
You can find more info here: https://community.arlo.com/t5/Announcements/Update-to-custom-modes-for-new-user-experience/td-p/2434874 -
@Mobb wrote:
Have contacted support multiply times they have even elevated to higher technical support and still simple scheduling does not work
They state they will call following day at a specific time but never do
New app has severe issues wish did not have to upgrade with new camera addition
If you can post the details of the schedule you want (ideally on a new thread), perhaps we can help.
Simple scheduling has been working reliably for me for several weeks. But if your schedule needs more than three modes, then it is not possible (at least not yet).
yes, a new thread as I get all the response too. To my thread/question. Thanks to those who help!
frustrated to the max. It was the software and it still could be SO MUCH BETTER if the controls we had previously were restored. More control of all the camaras PLEASE!
I have to respectfully disagree with you that this UI provides the exact same functionality as the previous UI.
While I have successfully set up a basic schedule to turn on and turn off my cameras — I also wanted to schedule just two Front Porch cameras to become active during the day while the other cameras are on Standby.
First, Support on chat and phone had no idea how to accomplish this. A SuperUser here gave me a workable solution — but it requires using all 3
modes. This is far from ideal since I would like to keep Arm Away as my easy option to simply enable when leave the house (and not have to disable then re-enable my schedules every time I leave and come home).
So that right there is a clear example of reduced functionality — as in the previous UI I could easily set any individual camera on any schedule I chose.
The helpful SuperUser then had a suggestion that would fine tune my own solution. My own solution is to simply set the Rules on Standby for my Fromt Porch cameras to be active while all other cameras in Standy are not. His fine tuning was to create schedules whereupon I would Add an Action to customize the sensitivity to 1 to prevent the cameras from running during those 2-3 hour stretches I want them off. Unfortunately this did not work.
i also originally tried to simply set those individual cameras to record/notify via Add Action. The problem is — the mode during that time is Standy. And those separate schedules to set individual cameras to record/notify simply don’t work. Nor can you set a schedule to then add action > stop record/notify.
So while this UI does allow a certain amount of scheduling it doesn’t allow for the wonderful flexibility of the previous UI.
Ive read this thread and even tried your suggestions and they failed to work.
I was given this suggestion as well — use Arm Away and Arm Home to establish different schedules for different cameras. It’s workable. But in the end when one leaves the house and you want to put your system in Arm Away mode — it requires you to have to disable schedules. And then when you return home you need to re-enable the schedules. Which not hard — but it is an annoying extra step that really shouldn’t be necessary at all. And just overall the UI is way overly complicated.
But thanks for taking the time to share your solution with everyone!
Can you provide more details on what didn't work? Ideally do that on your original discussion thread.
start a new thread, please
I did not know that! thanks.
I agree the UI and options are sorely lacking as compared to the previous. I hope someone @Arlo is listening!
Same!
as @StephenB suggested simply adding just one “Custom” mode would restore so much of the original functionality and flexibility!
Personally, I think it would work best to give the user the ability to create additional Modes on their own! That would all users to create a mode that could cover a wide range of configurations without conflicts. For example I work at home and need a front porch camera to come on during the day — so I could create a Mode and call it “Delivery.” And then I could create a mode that is specific for the day the housekeeper arrived to work. Etc, etc.
Thanks for response!
PS: Don’t know if the mods communicate with Arlo to pass along issues/suggestions from users — but it they definitely hear what we are saying.
I've been on the phone for over an hour and still no resolution. This is a nightmare. I had to turn off all the cameras because they were all active and going off like crazy! Why did the mess around with it. I am ready to throw them in the garbage.
Are you trying to schedule the cameras? Or are you having a different problem?
Arlo absolutely screwed the pooch with this update! Totally a dysfunctional system now with this update. I can’t imagine the Beta tested this update prior to its release. If so, they ignored the feedback! Do not buy Arlo products until they fix this cluster………!
Unfortunately, you can’t individually arm and disarm cameras. I spent 1:04 hour with Arlo support trying to get instructions to do this. The app can’t do it after the latest update. One comment that was made by the support person was as a result of all the negative comments and feedback from customers, Arlo is reviewing the update to see which features from the previous version should be added to the update. If I understood the foreign support person correctly, Arlo is looking at revisions to the update in the next month or so. But, don’t hold me to this because it was very difficult to understand the support person. Good luck folks! Hopefully Arlo personnel will listen to their customers!
Arlo has aslo announced that they will be adding back custom modes (or something similar) here.
But you can turn them on and off in the camera settings, which (though not exactly the same) is similar.
Unfortunately you can't turn the doorbells off (no idea why).
You can find more info here: https://community.arlo.com/t5/Announcements/Update-to-custom-modes-for-new-user-experience/td-p/2434...
Couldn’t agree more. I spent alot of time creating “modes” for arming various cameras and hubs with the touch of a button. Arlo decided that I only needed 3 modes now which make the cameras not user Friendly at all. I run my system on 2 Hubs I had it set up that I could have one hub armed independently from the other. Not any more I have lost that feature!!! I have recommended Arlo to everyone I speak to, that I know of at least 34 people have purchased Arlo. No more from me i have the next year to find replacement cameras.
- 2
Arlo Pro 4
labels
Samsung SmartThings
