Multiple rapid notifications for motion
  • 1693 Views
Roghatch
I have a Pro 4 set up to detect motion but not record.  I do this for an inside motion sensor to turn on lights when it is in Standby Mode and only record when the system is in ArmAway.  My issue is that I get multiple text notifications within one minute (sometimes more than 3 in 30 seconds).  In ArmAway mode, while recording, I get one notification that there is motion and a recording until the motion stops.  Is there a way to put a timed delay in motion notifications while in Standby so that I can reduce the number of motion notifications I get?
BrookeN
You can change the motion. sensitivity so that you do not get as many notifications. That may help with the amount of notifications you get.
 https://kb.arlo.com/000062895/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera-Arlo-Secure-4...
Roghatch
I can try it but my first assumption is that it is no longer going to be useful as a motion sensor to turn on lights if I reduce the sensitivity.
Do you want to turn on the lights when a person enters the field of view (but not when small animals, etc enter it)?
If so, then I suggest using the motion detection test while you move around in the area of interest.  Then you can find the smallest threshold that will detect you reliably.
Then use a threshold that is a bit larger in the camera rule(s) and see if that works for you.
  • 1693 Views
