Turning off notications for a period of time (Pro 4, Essential, Base)
  • 4 Replies
  • 1215 Views
SnohoGuy
I used to be able to turn off notification for various time durations (at no specific time of day) as I wished in the app.  So, for example, if I went out to mow the lawn, I would turn off notifications for two hours so I didn't trigger a notification as walked back and forth around the house.  I can't find that feature anymore.  Was it removed from the app?  Or am I just looking in the wrong places?  If it was removed, I hope it gets put back in.  All those notifications are annoying, not just to me but to other family members as well.  I could disable and turn back on, but when I've done that, sometimes I just forget to turn it back on and don't notice for a couple of days.
SnohoGuy
I take it all back.  I found it in settings.  I just mistook "Mute Notifications" as an on/off setting, but I see now that it has times.  Thanks.  You helped me look a little closer at the right thing.....even if it took two times.
Do you see "Feed" and "Dashboard" in the app?  Or do you see "Library"?
If you see "Feed", then press on the profile icon in the upper left of the app screen. Then select "Notifications".
There's a "Mute Notifications" control there - press it, and you will see the options for 30 minutes, 1 hour, 3 hours and 24 hours.
SnohoGuy
I see Library, but I don't see Dashboard or Feed.  I don't see any ability to mute notification in Library.  I'm using the app on Android, but I don't see Dashboard or Feed on my laptop either.
It should be in Library also, but I'm no longer using that so cannot verify.
SnohoGuy
  • 4 Replies
  • 1216 Views
