  • 5 Replies
  • 1472 Views
Steve40
I need to prove that I have every recording that took place on a recent day. If I just show the recordings, someone could say that I omitted some. Is there a log that Arlo could provide that lists all of the recordings so I can prove that every recording is there?
DannyBearAgain
If you’re the main account holder and have a subscription plan for the cloud storage you should direct your request to arlo customer support.
Open your arlo mobile app and select the settings menu and choose support. Select your pro4 camera and review the support contact options for a direct contact number.
Else private message an arlo moderator here on this forum, @JamesC@ShayneS@BrookeN
5 REPLIES 5
DannyBearAgain
If you have the cameras connected via a arlo Base station with backup storage enabled you can reference the metadata file entries with the backup recordings within the storage device.
Steve40
Thanks for the reply. I have Arlo Pro 4's and a cloud account for storage, so would probably need something from Arlo or something from the portal I can access.
DannyBearAgain
Steve40
Thanks again...after contacting support, it appears that the information I want is not available.
I had a package "delivered", but according to my cameras they never showed up. I was hoping to prove this by showing camera recordings along with a log from Arlo that shows all of the recordings for that day (basically proving I hadn't deleted any recordings).
Unfortunately the cameras don't always trigger, so the log wouldn't be definitive proof. Still worth sharing what you have, hopefully it will be enough.
  • 5 Replies
  • 1473 Views
