Is Pro4 not compatible with Google wifi
@pelo01 wrote:
there is no way to control whether the phone is linked via 2.4 or 5.0 Ghz. Does that mean Pro4 cannot be used with Google wifi?
No. Although I don't use Google WiFi, my Orbi Mesh system (like most mesh systems) also has a unified network name for both bands (and gives you no way to disable 5 gHz). However, I have been able to onboard cameras to my home wifi.
I'm unclear as to whether you've successfully onboarded your camera or not. Are you saying that you are hearing the chime after the QR code is scanned, but then the camera doesn't end up added to your account? Or are you running into a different issue?
I’m also having this issue. After scanning the QR code it chimes, goes to the looking for nearby camera screen and then is unable to “find” a camera.
has anyone been able to figure out how to make it work with the dual band google wifi?
Arlo Pro 4
labels
Samsung SmartThings
