How do I open the case for the pro 4
How do I open the case for the Pro 4 camera?
It says push the button - what button?
Best answers
The button next to the magnetic charger connection. You can see it on the attached picture.
Note that if you want to fully detach the case, you press the button once, and slide the camera body out part way. Then press it again, and it should slide out the rest of the way.
Arlo Pro 4
labels
Samsung SmartThings
