I keep deleting 2 videos from my feed on the app and a few minutes later they come back. Any ideas how to stop this?
A cloud fix was released that should resolve this issue. Please test again to see if you still experience this behavior.
Try force closing the app and flushing the app cache. Any better?
@Vlsjogren: Note you can't flush the cache on iPhones running current iOS, only with Android.
You might also try deleting the video using a browser (my.arlo.com).
I didn't realize that had changed (or maybe never happened). The brute force method, then, of deleting and reinstalling the app may work.
Thank you. I’ll try using the pc at the website because I am on iOS. If that doesn’t help will delete and reinstall the app.
I’ll update this post tonight and label it a solution if it works.
You could also ask arlo to back date the app version to something that’s usable.
We have two that keep doing that as well. Are they from January 31st by chance?
Yes, that was the date. I tried several of the suggestions but nothing worked, then suddenly they went away yesterday.
Yes it is fixed now!
Arlo Pro 4
labels
Samsung SmartThings
