Looking to see if I can add these to current base station before I buy them?
4.2 out of 5 stars 768Reviews
Arlo Pro 4 Spotlight Camera - 3 Pack - Wireless Security, 2K Video & HDR, Color Night Vision, 2 Way Audio, Wire-Free, Direct to WiFi No Hub Needed, White - VMC4350P
You can't add them to a VMB3000. You could still use them, since they can be connected to your home wifi.
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
Arlo Pro 4
labels
Samsung SmartThings
