Camera pro 4 charging issue
  • 4 Replies
  • 9587 Views
whbro89
I have 4 cameras, but only have this charging problem with one of them. Whenever I try to charge this camera, the camera won't charge.
I did proceed with the solution that I received from the automated service in Arlo, but nothing worked.
- The blue LED light didn't appear when I plugged in the charger with the battery intact within the camera, the blue LED light showed when I plugged in the charger without the battery intact.
- Have swatched battery from the camera that works into the camera with the one I'm having trouble charging, but still not charging.
I can't talk to live agent as Arlo says I'm not subscribed to live agent support. If this is the case, how can I get this camera back into working condition?
whbro89
The factory reset was the solution!
It's back to normal now and the battery's now charging!
Thank you so much!! 👍
Is the camera still under warranty?
whbro89
No it's not.
@whbro89 wrote:
No it's not.
The hardware isn't repairable, so if that is the cause the only options are to
You could try a factory reset, and see if that helps.
whbro89
  • 4 Replies
  • 9588 Views
