Arlo Pro 4 2-Way Sound iOS 16.3.1
- My iPhone 13 Pro would not work with 2-way comm. I could speak from my phone but not hear. The version 4.1 speaker icon would not respond to a screen tap. It worked correctly on my iPad, however
- After trying everything that I could on the iPhone, I finally uninstalled on the iPhone and reinstalled 4.1. Now it works fine
- I am still having a problem with cameras dropping offline and then coming back online after a bit. I am not using a base station
- So I am making progress but still tuning
DWMBTown,
What does the signal strength icon show for the cameras? Dropping offline intermittently is often an indication of interference or range issues. If you temporarily move the cameras close to your router and test, do you still experience the same behavior?
Arlo Pro 4
labels
Samsung SmartThings
