  • 7 Replies
  • 3644 Views
Camera-5
 does the red lines mean my battery is no good ? The camera won’t link up at all.
7 REPLIES 7
None of the batteries I just checked have that icon so I can't be sure. Mine have been around for a while so it's possible a different batch or even vendor was used. Have you used a voltmeter to check the voltage as measured by touching the connections marked + and -? I get a reading of about 4.25 volts DC on a charged battery.
Camera-5
I appreciate the response.  I think it’s a software issue with the camera itself.  I may try and update it again and see if that fixes the issue of not linking up to my wifi
ShayneS
Hi @Camera-5
This looks to be a red water indicator.
If this camera or battery was purchased new from Arlo or one of our retailers within 12 months, we should be able to replace it for you.
Camera-5
I have 5 cameras.   I’m not sure why that particular one would begin to have a water issue.   How do I check to see if it’s warrantable ?
Camera-5
 here is the picture of the camera info.
 It's possible that the o-ring is damaged, missing or not properly positioned, letting moisture inside.
ShayneS
Hi @Camera-5
I have escalated this for you and Support will be reaching out as soon as possible.
Thank you
  • 7 Replies
  • 3645 Views
