Battery not fully charging
Hi,
Recently bought 2 arlo pro 4 cameras, however when i place them on charge they only charge up to 35%, which means I have to charge again in another 4 days. Is there any fix for this issue? Extremely frustrating...
Thanks.
Are you using an Arlo charger? If not, what are the charger specs?
My own Pro 4 charges to 100%.
Hi Stephen,
Yes, using the magnetic charging cable supplied in the box. Both cameras only going up to 35%.
But what about the charger?
5 volts, 2.1 Amp??? Or something else???
Arlo Pro 4
labels
Samsung SmartThings
