Have you tried moving the hub to a more central location. You can connect the hub to a wifi extender or powerline extender with an Ethernet connection. I have a smart hub on one end of the house and it connects fine with a camera beyond the other end of the house. Also try moving the Base/hub at it's current location as far as the cable will allow from the router as it is a common problem with interference being to close along with house construction.
@DoubleA wrote:
. Arlo should just update firmware and let it work with HomeKit without a hub.
That would be ideal, but of course isn't the case now.
In the meantime, you either need to place the base(s) within range of the camera(s), or you just wait and hope that Arlo will eventually add homekit support w/o a hub.
Arlo Pro 4
labels
Samsung SmartThings
