I just purchased a dual camera Arlo Pro 4. I live in a building that provides high speed internet/wifi but I do not see that they have a 2.4 GHz at all, only 5 GHz. Is it useless for me to have these cameras as in no shot of getting them connected to the wifi the building has? Even their gest wifi is 5 GHz. The cameras are of the highest rated for home which is why I got them.
It is a bit odd that they don't provide any 2.4 ghz. Have you contacted them and asked?
You could potentially buy a WiFi extender that connects to the 5 gHz wifi, and creates a 2.4 ghz network. Then connect the cameras to the extender's network. Something like this would work: https://www.netgear.com/home/wifi/range-extenders/ex3700/
One thing to add - some commercial wifi networks use RADIUS authentication - requiring a user login/password in addition to the wifi password. The Pro 4 camera can't handle that - there's just no way to tell it to use those extra credentials.
Arlo Pro 4
labels
Samsung SmartThings
