Blue Motion light not working
  • 4 Replies
  • 2087 Views
Helpful2Me
2 of my cameras have stopped recording. I can manually record. The blue motion detector light is not on. I have Restarted, Taken battery out & then back in, Turn camera off then back on to no avail.
Have you checked that the camera is armed?
Have you tried the motion detection test?  https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
Helpful2Me
Yes camera armed & yes to test
Odd that it won't detect motion then.
Does swapping one of the misbehaving cameras with one that is working result in
  1. the problem staying with the camera?
  2. the problem staying with the location?
You could try Arlo support (use the options in the app - you should see phone support there, since you have a subscription).
I guess you could also do a factory reset on the camera.  https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Just to note that there is no blue motion detector light. The blue LED on the camera denotes things like power attached, battery charged as well as for onboarding the camera. The issue of not recording is unrelated.
  • 4 Replies
  • 2088 Views
