  • 2 Replies
  • 5073 Views
steve392
I just purchased a 3 pack of Arlo Pro 4 cameras from a Best Buy exclusive deal. These cameras came with the Anti-Theft mount. No problem there, maybe they were included to meet a certain price-point. After opening the package and inspecting the mount, I see that the mount is integral, for all intents and purposes with the camera case, and if I wanted to use the indoor magnetic wall mount (VMA5000) I would need to buy a different camera case?
Please advise what mounts will work with this camera and if different cases are required depending on the mount.
I was aware that different mounts were available, but nowhere did I see that Arlo mentions that the entire case needs to be changed if I decide to change mounts. Arlo should make this clear in their product information.
Thanks,
Steve
Yes.  One of these two
That will work with any standard screw-type mount, and also the indoor magnetic mount.
steve392
Got it, Thanks for the quick reply.
  • 2 Replies
  • 5074 Views
