  • 1 Reply
  • 529 Views
ArloWontCharge
I bought an Arlo Pro 4 in July. It worked fine until about 10 days ago. Now the battery runs out after 2 days. I’m not getting excessive alerts. I’ve disconnected and reconnected it. I’ve turned off the spotlight. I moved the hub to the other side of the router. It updated firmware a couple of days ago. It’s useless if it only lasts 2 days. Anyone have any ideas?
Deactivate the camera in Settings, Smart Notifications so you see all recorded videos (Smart will discard videos that are determined to not be according to your settings so you don't know for sure how many recordings you're getting). If nothing works, try bringing the camera closer to your hub to see if that helps. If you have more than one camera you can swap them around to see if it's the location or camera.
  • 1 Reply
  • 530 Views
