  • 812 Views
rowoflo
I would like to buy a spare battery for my Arlo Pro 4 XL. I think this is the correct battery (https://www.arlo.com/en-us/accessories/VMA5410-10000S.html), but I am not sure if my charger (standard magnetic charging cable) will work with it without the camera completely assembled.
Basically I would like to have a spare battery that I can charge and pop into the camera when its battery dies. That way there is not a lapse of camera coverage when the camera is charging.
That's the correct battery.  You'll end up with a spare housing that you don't need.
To do that you'll need to get the VMA5400C-100NAS as well.
rowoflo
I had seen that charge but it didn't look like it fit the larger batteries. Good to know that it does. Thanks for the info!
The difference in battery size is only length so all batteries from the Ultra on will fit.
  • 813 Views
