  • 5 Replies
  • 1936 Views
Erdynep
Arlo Pro 4
VMC404 1P
My Arlo was working fine along with the other 2 cameras until I recharged it. The app said it was offline. I have followed the factory reset steps by removing the device from the Arlo Secure App, removing and re-inserting the battery and holding down the sync button for over 15 seconds.
Now all the Pro 4 does when the battery is reconnected is first shine a blue light and then change that to amber then no light. It then continuously, every 10 seconds or so, blinks amber twice.
I am unable to re-add it to my Arlo Secure App as I do not get to the blue flashing light stage.
Any ideas what I should do next?
Use Settings, Support for the camera to see what support will do for you.
5 REPLIES 5
The slow amber blink implies a dead battery. Can you swap batteries around to see what happens? WHen charging in the camera, the camera LED should turn on steady blue when fully charged.
Erdynep
Thanks. I have just connected the charging cable back on and now the LED light is going through a repeating sequence of:
1) rapid blue light flashing for around 3 seconds
2) steady blue light for 2 seconds
3) then a quick amber light
4) 5 seconds of nothing and then back to 1
I am now charging both of my cameras
Erdynep
I have charged both cameras again and swapped the battery back and fore. My working camera shows 100% for both batteries and works with both. My now dud camera has a slow flashing blue light. About 10 seconds between the blue light turning on for a second and then off again
Erdynep
I let the camera discharge as much as possible and then did a full recharge and a factory reset and managed to get it to connect. I didn't do anything different to what I had done before so not sure why it worked this time. If it had of failed I would have done as you suggested and gone to their support, but hopefully all good now and remains that way.
  • 5 Replies
  • 1937 Views
