Arlo Pro 4 120V AC Power
  • 4 Replies
  • 1916 Views
  • 2 Likes
dndminkus
Is there an 120V AC power adapter for the Arlo Pro 4 camera for outdoor use?
@dndminkus wrote:
I am wondering if the supply end is like a regular plug that gets plugged into a regular power outlet?
Yes it is.  The other end on the US charger looks like this:
The pictures are a bit misleading - these aren't just cables.  They have an integrated power adapter at the end that isn't shown.
dndminkus
Thank you for your reply.  Since it does not show the actual plug end, I am wondering if the supply end is like a regular plug that gets plugged into a regular power outlet?  I see that the camera end appears to be magnetic.  Thanks again for your reply.
dndminkus
Thank you so much.  This helps tremendously!
  • 4 Replies
  • 1917 Views
  • 2 Likes
