Is there an 120V AC power adapter for the Arlo Pro 4 camera for outdoor use?
@dndminkus wrote:
I am wondering if the supply end is like a regular plug that gets plugged into a regular power outlet?
Yes it is. The other end on the US charger looks like this:
- https://www.arlo.com/en-us/accessories/VMA5600C-100NAS.html
- https://www.arlo.com/en-us/accessories/VMA5601C-100NAS.html
The pictures are a bit misleading - these aren't just cables. They have an integrated power adapter at the end that isn't shown.
Thank you for your reply. Since it does not show the actual plug end, I am wondering if the supply end is like a regular plug that gets plugged into a regular power outlet? I see that the camera end appears to be magnetic. Thanks again for your reply.
Thank you so much. This helps tremendously!
Arlo Pro 4
labels
Samsung SmartThings
