Arlo 4 not in feed
I just assumed a system from previous homeowner.
3 Pro 2 cameras and 1 Pro 4.
The pro 2 motion alerts all show up in the feed, however the Pro 4 does not.
I do get the motion alerts/notifications to my phone, just not a recorded video snippet. I have the settings to record a 30second video.
Why is this? I have tried all troubleshooting listed on the website re: videos don't show up in feed.
Why is this?
The Pro 4 camera requires a subscription for cloud storage. Likely you haven't gotten one.
Is there a way around this like physical storage, or is a subscription necessary?
IMO the subscription has the best user experience. US cost for a single camera is about $5 USD/month. You can also get an annual subscription about $48/year. Details are here:
- https://kb.arlo.com/000063083/What-Arlo-subscription-plans-and-cloud-recording-options-are-available
They don't refund anything if you cancel, so I suggest starting with the monthly initially. You can cancel it, and then resubscribe annually if you want to save a little bit later on.
The subscription has some other features - including activity zones and smart notifications. And phone support.
If you have (or are willing to purchase) a VMB4540 or VMB5000 smarthub, then you could set up direct access to local storage. Note other Arlo bases do not have this feature. There should be a VMBxxxx label on the base. You'd then need to attach storage to that smarthub - at least 16 GB. Generally 128 GB or 256 GB is more than enough, so a flash drive (VMB4540) or a microSD card (VMB5000) is fine.
More details on the feature are here:
It isn't great (IMO, intentionally so). Limitations include
- recordings only available from the primary account (not "friend" accounts)
- recordings only available from the app (not my.arlo.com)
- no ability to make manual recordings or take snapshots
- no thumbnails - videos need to be downloaded to the phone before they can be viewed
- remote access requires router setting changes that many find difficult, and which don't work with some internet service providers.
Arlo Pro 4
labels
Samsung SmartThings
