Arlo 4 Pro Battery Failures
  • 2 Replies
  • 2794 Views
Ray_xyz
The battery in my Arlo Pro 4 fails after a few months on the charger. This has happened twice. Is there a way to operate the camera all the time on the charger, with or without the battery installed  And without any battery failures.
Have you tried using a different charger? That could be an issue. However, you have a warranty to resolve issues like this so use Settings, Support to select your camera model. Scroll down to Contacts and talk to official support.
Ray_xyz
Thank you for the suggestion.  I found my other charger and the camera charged up to 99%.  It's been working all day.  Hopefully, this means the battery is okay.  Now to find another charging block to run the camera long-term.
The camera seems to be beyond the warranty period.
  • 2 Replies
  • 2794 Views
