  • 2 Replies
  • 849 Views
ansongor
Hi,
The library keeps loading but not showing any recordings. I tried wifi, 4g conntection, reset the home station by the button behind, reinstalled the app, formatted usb flash drive, changed a new usb flash drive. Devices are in the latest firmware. None of these work.
dcfox1
@ansongor wrote:
Hi,
You do have the VMB4540 Smart Hub you listed correct? My pull down for the 4540 shows Smart Hub not Base like your photo.  If you have a base model you won't be able to see local recordings in the app.
I assume you no not have a current subscription for cloud recordings since your talking about local not cloud.
What is Direct Storage Access and how do I use it? (arlo.com)
ansongor
Hi
That’s just a name can be edit as any other name.
  • 2 Replies
  • 850 Views
