  • 1 Reply
  • 511 Views
Rxguy
Using the Arlo base stn hub, and it has worked fine for 2 years.  It is always plugged in to power, but now it won't keep up.  Very little use on the camera and the drain is about 1% per hour.  The charging symbol lightening bolt is showing.
I have changed the battery, the 5 volt charger and still no help.  Is the base station a possible problem or do I just trash the camera?
Move the camera closer to your base to see if the battery drain improves. It could be an excessive signal strength/quality issue.
  • 1 Reply
  • 512 Views
