@Mopareg wrote:
Swapping, problem did move I am going to return camera to best buy
If the problem moved, then the problem would be the battery.
Are you using the arlo supplied charger cable, and recommend adapter or using a charging station?
@Mopareg wrote:
battery will not charge, why?
Also, are you using the outdoor charger with the magnetic cable?
Or are you using the microUSB port inside the camera housing?
I am using the supplied micro USB adapter and cable
Do you have a different cable or charger you can try (5 v, 2 a)?
Tried a 2nd charger from another pro3, still no go
The indoor charging cable for the Pro 3/Ultra won't charge the floodlight - you either need to use the outdoor charger, or the internal microusb port.
If you used the microusb port, then maybe try a different cable.
Charged my other pro3 flood ok, I am using adapter & cable that came with the pro 3 flood camera
Try swapping the batteries and see if the problem moves.
Problem is battery, but since I recently purchased camera and best buy will not trade me agood battery I must return entire pkg
