My videos are recorded locally to USB however nothing is showing in the library. Realise that only activates the record when its within the criteria for recording so tested it by walking up and down driveway but whilst I can see on the 'live' feed nothing is being saved to the USB. Pointless if I cant access anything 'just in case' there is some incident I need to look back on. Any clues please. Ive restarted all the devices, the smarthub and my wifi router also just in case.
Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue. Bumped into your thread. Thanks for creating it. Looking forward for solution.
Similar issue. Getting notifications, lights going on, , Live working, not recording to Library...........frustrating
Do you have a subscription for the camera(s)?
I have the free first 90 days subscription
One of the cameras is recording to library, other 3 are not.
They all did couple days ago..........3 just stopped
rwkndhy,
Do you have a filter enabled within your library? If you view the library using the app and the web client via PC do you experience the same results?
Interesting
When I look on PC everything shows up.
On my phone only 1 camera is posting to Library....
Any clues???
Appreciate any help
rwkndhy,
If the videos show up on PC, it seems likely that you have a filter selected when viewing your library on your mobile device.
Check your library filter by tapping the funnel icon and remove any filters you may have selected.
Thank you ! ! !
