  • 7 Replies
  • 3217 Views
David100
Anyone know why my cameras are suddenly just recording for just one or two seconds?
David100,
Within your active mode, you can adjust the length of the recording so that it's fixed or until motion stops. If you would prefer a fixed length, edit your active mode or create a custom mode and define the rules accordingly.
For more information, see here: How do I adjust Arlo video recording length?
7 REPLIES 7
Start by rebooting the hub. If still a problem, the frequent issue is signal strength/quality is causing the video to stop.
David100
I did a restart , I'll try a hard reboot at home. Thanks for the reply.
David100
Still having issues with one or two second recordings, even after rebooting. Cameras are basically taking snapshots. If anyone else is encountering this please let me know. Maybe the next "update" they do will help.
David100,
What does the signal strength indicator show for the cameras?
David100
Appears to be good. Sometimes they will record longer. I've had this system for over a month and this just started last week.
On the old system you could adjust how long you want to record when tripped. I don't guess there is a way to do that on the pro 3.
David100,
David100
Thank you so much for that!!!!!!!!!!!!!!
  • 7 Replies
  • 3218 Views
