VPN support Thailand
  • 4 Replies
  • 2331 Views
Barryuk
I would like to use Pro3 / Pro 4 ca etas in Thailand - I’m wondering if anyone has done this either by using a VPN or otherwise, Thanks
I'm not familiar with Express VPN but it would seem to be true. The key is that everything in the house must use that VPN, at least for setup.
Folks have used a VPN in the past successfully. However, it would need to be a full VPN connection from your network to a VPN server since all devices would need the same connection. A VPN server created by your router won't work.
Barryuk
Thank you - so if the cameras are connected to the Arlo hub, which then connects to a router with express vpn installed at router level would that work ?
Also, the account needs to be created while you are connected to the country you want to subscribe in.
  • 4 Replies
  • 2332 Views
