I used to be able in the Arlo App on my Android phone see in "Library" a choice between Arlo's Cloud Storage and my Arlo Smart Hub (VMB4540). If I chose the latter (i.e., the Arlo Smart Hub), I could see on my Android phone the video recordings from my Arlo Pro 3 cameras that were saved to the local USB device I had plugged into my Smart Hub. A couple weeks ago, I acquired an iOS phone and installed the Arlo app there. Since then, I can no longer view any video recordings saved to my USB device on either my old Android phone or my new iOS phone. Any idea why? And what can I do to be able to view on my iOS phone's Arlo Apps the ecordings saved to my USB device connected to my Smart Hub?
Solved it.
Solved it.
