Hi,
I bought the set of Arlo Pro 3 cams (3nos) with VMB4540, 3 cams and VMB4540 are working fine with Arlo Cloud, but NOT working under port forwarding.
I try a tons of times of router setting, set the port forwarding, open the port of 443 and 80, even set the VMB4540 in DMZ then Power cycle the VMB4540, the status of Port Forwarding still showing "Not Available".
I don't know why the VMB4540 is not working on that but fully working with Arlo Cloud.
Who can help me to solve this problem?
Or just a marketing skill of Arlo Cloud? 🙂
Port forwarding is used for when you're not at home on your home network. Turn off WiFi and see if it works then.
YES!!!
Thank you for solving my problem.
