"To access recordings when outside the LAN, we recommend enabling VPN on your router and mobile device to establish a secure connection to your SmartHub."
I am looking to install seven (7) Arlo Pro 3 cameras connected by two (2) Smarthubs across my property due to the wide range that needs to be covered (5 cameras to one Smarthub and 2 cameras to the other). I want to only use local storage and have researched as much as I can about the products online but haven't found a definitive answer on capabilities when it comes to my type of proposed setup:
- Can you split the cameras to connect to multiple Smarthubs all under one Arlo account so that it can all be managed as one single system within the mobile app?
- If I only connect one 2TB USB hard drive to to one of the Smarthubs, will it store all captured video from all seven (7) cameras? Or do I need to connect one hard drive to each Smarthub?
- On the Arlo website, it states that I can only view locally stored footage when I am connected to the same LAN as the Smarthubs. Does this mean that I cannot view locally stored videos on the hard drive when I am out travelling or away from the property? I also want to give viewing permissions to some family members, does this mean they cannot see locally stored video recording and can only view live video? Will I or family members only be able to view live video when we are away from the property, and on LTE or a different WiFi network, and not any locally stored video?
- It seems CVR isn't available if i use local storage only correct? I will only be able to view recorded clips from motion or audio detection?
Thanks!
@arlo3question wrote:
Thanks for your response! I guess my question now is, whether or not there is any way to view footage remotely without the need for a cloud subscription as that comes in as the most costly in the long run?
I covered that in my response.
What is Direct Storage Access and how do I use it?
Not the easiest thing to set up, it requires some fiddling around with port forwarding or VPNs. But it does work.
Just another user
Thanks!
- Yes - you can add hubs to one account. I have three.
- No - cameras record to their hub
- No -
- Yes. CVR needs a cloud account. Yes.
That's the bare bones, but there are hidden subtleties that you can turn to later.
Just another user
Thanks for your response! I guess my question now is, whether or not there is any way to view footage remotely without the need for a cloud subscription as that comes in as the most costly in the long run? Might need to turn to another product if not.
Just another user
OK. I interpreted "more distance for motion detection" as wifi reach.
The Q Plus is also better than other cameras at looking through Windows.
Just another user
